configure radius tls ocsp
configure radius tls ocsp [ on | off]
Description
This command configures Online Certificate Status Protocol (OCSP) globally for all RADIUS TLS servers.
Syntax Description
tls Specifies Transport Layer Security (TLS).
ocsp Specifies the OCSP attribute.
on Specifies turning ON OCSP for all RADIUS TLS servers.
off Specifies turning OFF OCSP for all RADIUS TLS servers.
Default
ON.
Usage Guidelines
This is not configurable per server.
The following example turns off OCSP for all RADIUS TLS servers:
# configure radius tls ocsp off
This command was first available in ExtremeXOS 31.4.
Platform Availability
